It is currently Sun Jul 20, 2025 6:56 pm
PostPosted: Fri Oct 13, 2006 11:57 am
anyone have sound port pix or construction tips to post?
Buscarino below
Terry Stowell39004.382662037
PostPosted: Fri Oct 13, 2006 12:17 pm
Here's a couple I made.
One is in the works and the other was on my wife's mother's day present!
PostPosted: Fri Oct 13, 2006 2:09 pm
First name: Tracy
Last Name: Leveque
State: CO
Here's my last one on the irish bouzouki
Those are all great looking sound ports!
PostPosted: Sat Oct 14, 2006 12:49 am
Do you guys cut the sound port before or after bending the side? I would imagine that cutting it after the bending would make it a lot easier to get in the right spot, but it seems like the bend in the bout would make it difficult to cut that way.
Thanks!
PostPosted: Sat Oct 14, 2006 1:29 am
I did this one on my last SS. I cut it with a dremel w/ Stew Mac router
base, after bending, but before attaching back and top. I cleaned it up
with needle files and a jeweler's saw.
PostPosted: Sat Oct 14, 2006 2:07 am
First name: Tracy
Last Name: Leveque
State: CO
Graham,
I bend the sides first, then glue in a 2 layer veneer of black/white using foam and clamps so it conforms to the side. Then process the sides as usual with kerfing, then tape your picture in place and use a dremel to cut out the large areas. I then clean up with needle files to file down to the line. Hope that helps.
PostPosted: Sat Oct 14, 2006 3:35 am
WOW, great thread Terry, thanks!
Nice soundports guys, keep them pics coming and thanks for the input!
PostPosted: Sat Oct 14, 2006 3:39 am
Thanks for the descriptions guys. That really helps. I think on my next build I will give that a try.
